I am looking for a FREE Test management tool. This would be a Jira plugin.
I see a few free options:
https://marketplace.atlassian.com/search?query=QA+Test+Tool+management&price=paid
Can anyone please suggest a few? Thanks so much!
You can try QAlity - Test Management for Jira which is free app that was developed by SolDevelo, the company I work for.
The app allows you to create test cases, which are in the form of Jira issue. In such a test case you can add test steps, test data, expected result and test attachements.
Moreover, the application allows you to create a cycle test.
In our documentation you will find a list of features that are available in the free version.
The paid version - QAlity Plus - Test Management for Jira - gives you many more options and if you like the free version you can always try the paid version for free for 30 days during the trial period without losing any data.
If you have any questions then go ahead and contact us through the service desk.
Michał
SolDevelo Team
Thank you Mikal! I'll check it out. Appreciate you reaching out.
Hi Michał,
Would I be able to export Xray test cases from Jira and import them into QAlity?
The import and export functions are not available in the free version, but you can install the Plus version and import test cases during the 30 days period of free trial. After the trial you can either continue to use the Plus or free version without losing your test cases.
Please check this migration guide that's available in our documentation.
Let me know if you have any additional questions.
Michał
SolDevelo Team
Hi Michał
Thank you so much for the information ! I will check it out. I appreciate your attention and quick responses!
Rene
It depends on your specific needs and environment. The "right" tool for one team or project may not be the best fit for another due to differences in workflows, team size, integrations, and overarching goals. You'll need to do the homework and see which one fits your needs the best.
However, when judging Marketplace apps, I often first look at the number of installs and compare them to the reviews.
Thanks very much. I will doing my homework, but thought someone could throw out a recommended name of one to start. Appreciate it.
