Looking up Hipchat handle in groovy script
Ryan Deyer
I have a groovy script running as ScriptRunner listener.  It pings our HipChat rooms from the script.  The code to @mention a user in the script, which works, is <hc-mention>@ryan</hc-mention> for example.  My question is how I can lookup in the groovy script what a user's @mention handle is. If they were all the same format I'd be fine but people can adjust their handles and make them just first name for example.  I need a way to look them up in the script.
crivers
March 3, 2017
In order to look up a user's mention, you either need to compare it to the list of all users by calling https://www.hipchat.com/docs/apiv2/method/get_all_users or you need to have the user's ID and call https://www.hipchat.com/docs/apiv2/method/view_user. If you keep a local cache of all the users that gets refreshed periodically, this could help you do the lookup more quickly.
Ryan Deyer
Thank you Chris.  I'll give that a try.
Normann P. Nielsen - TDC/Netic October 26, 2017
Hi Ryan,
Want to share some basic code? I cant get Hipchat to work with Groovy, just get 401 or 400.
Works fine from CURL and Powershell....
BR,
Normann
Help us plant more trees
