Hey there,
I have a request type for leaving employees where I use a user picker (custom field) to define the employee who is leaving.
When the ticket is created I would like to have an automation which links all the issues where this user was the reporter to this leave ticket.
I have tried to use the Lookup issues function to list all the tickets where this defined user was the reporter but it didn't accept the filter I have put it.
reporter = {{issue.Employeename}}
Employeename supposed to be the custom field with user picker type. The Validate query is even greyed out.
There is some hint on the page that I should use user IDs.
I would be thankful for any help.
Best,
Geza
Hi @Geza Kukoda
If Employee Name is the name of your field, please try this for the Lookup Issues JQL
reporter = {{issue.Employee name.accountId}}
And the "Validate query" option is grayed out because your JQL is based upon dynamic information the rule supplies at run-time, and it cannot be checked as the rule is defined.
Hey Bill,
Thanks for the prompt solution. It worked. :)
Best,
Geza
Probably to get the custom field value, you might need to use like below:
${issue.fields.customfield_10051} or ${issue.fields.customfield_10051.accountId}
here put the custom field id
(get it from <url>/rest/api/2/issue/issue key/ and search for the data of the field and get the custom field id)
also, kindly go through https://developer.atlassian.com/cloud/jira/platform/deprecation-notice-user-privacy-api-migration-guide/
Hey Piyush,
I am working with the automation page on the settings and not with the API. But sure thing the .accountID was the missing point.
Thanks for replying.
Best,
Geza
