Lookupissues to get specific number of issues
Sidharth verma September 12, 2024
I want to get a specific number of JQL issues from the lookupissues Object list that is returned. I understand that we have
{{lookupissues.get(index)}} which can give us a specific object in the list.
can i pass a variable in place of an index so that I can fetch the value from somewhere and depending on that value it should return me (0 to Index) number of issues. my goal is to get a specific number of issues from a JQL and the number of issues should also come from a variable. looking forward to hearing from you all.
do let me know if i need to further clarify
September 12, 2024
Hi @Sidharth verma
With the Lookup Issues action, there is no way to dynamically access a specific number of issues.
One alternative is to use the REST API if your number of issues is 100 issues or fewer:
If you want to try this approach, here is a how-to article for calling the REST API from a rule: https://community.atlassian.com/t5/Jira-articles/Automation-for-Jira-Send-web-request-using-Jira-REST-API/ba-p/1443828
Sebastian Krzewiński
September 12, 2024
Hi @Sidharth verma
Did you try to create variable in Create variable action and use it later in rule?
Seba
Hi @Sebastian Krzewiński
Yes, i tried but its giving me the below error:
Failed to get value for lookupIssues.get({{nfreePackagers.asNumber: {{lookupIssues.get({{nfreePackagers.asNumber}}).key}}
I get the same error when i try without converting it to number format as well:
Failed to get value for lookupIssues.get({{nfreePackagers.asNumber: {{lookupIssues.get({{nfreePackagers}})}}
