Make Autotransition in Jira
Андрей Зонин October 21, 2019
PROBLEM: There are two Jira projects: A & B. When project A transitions, project B should as well. Issues from projects A & B are linked.
RESEARCH: There is an ILA plugin for Jira and in its Update Status Transition you can select issues with JQL and set their statuses.
http://i.imgur.com/CnmLHi5.png
I've conducted a JQL, but it is related to current issue, and I need it is a variable which is unavailable (find issues of project A, linked to issue B-3 from project B):
project = "A" AND issue IN LinkedIssuesByJQL("issue = B-3")
QUESTION: How to refer to a variable like $currentIssue? Any other free plugins? Maybe using Jira API?
Andrew Laden
October 21, 2019
There are many options out there to do linked transitions:
Jira Misc Workflow Extensions has a transition linked issue post function
https://innovalog.atlassian.net/wiki/spaces/JMWE/pages/68878506/Transition+linked+issues
https://marketplace.atlassian.com/apps/292/jira-misc-workflow-extensions-jmwe?hosting=server&tab=overview
JSU Automation Suite for Jira Workflows Also has one
https://confluence-apps.beecom.ch/display/JSU/Linked+Transition
https://marketplace.atlassian.com/apps/5048/jsu-automation-suite-for-jira-workflows?hosting=server&tab=overview
You can also (partial list)
  • Automation for Jira, (this one was recently purchased by Atlassian)
  • one of the scripting addons. (scriptrunner,power scripts)
  • Jira Workflow Toolbox
So there are many options. Take a look at each of the addons and see which one has the most features that you would use in addition to linked transitions. They are all good choices, and all have their pros and cons.
Denise_Wuethrich_beecom_products
Linked transition is really a powerful feature in JSU. Using JSU you can target not only linked issues, but also related issues like parent/sub-task, issue link, Epic./Issues in Epic. You can even customise the target issues using JQL. In your case, you can use JQL like  issue in linkedIssues({issue.key}, "clones") and project ="Project B"
You can also synchronise data inputs across related issues, and copy values from one issue to related issues without coding. See the helpful documentation here to find out more: https://confluence-apps.beecom.ch/display/JSU/Linked+Transition
Hope this helps.
Denise
Kevin Johnson
Sync fields is a plugin which is used to change and replicate all the data that is in a issue to another issue in other project ,may be this is similar plugin.
https://marketplace.atlassian.com/apps/1214812/sync-fields?hosting=server&tab=overview
Hope this helps
