Make attachment mandatory at issue creation
Aimane SBAI
Hello Atlassian heroes,
I would like to make attachments mandatory (under condition) at issue creation (Customer portal).
Here is my scenario : IF customfield1 = value1 AND customfield2 = value2 THEN attachment is mandatory.
To achieve this, I did create a "Simple Scripted Validator" at Create transition.
Here is my script :
def attachmentManager = ComponentAccessor.getAttachmentManager()
def hasAttachments = attachmentManager.getAttachments(issue).size() >= 1
if (cfValues['customfield1']?.value == "value1" && cfValues['customfield2']?.value == "value2" && !hasAttachments){
return false
} else {
return true
 I did also try this :
import com.atlassian.jira.issue.Issue;
import com.atlassian.jira.component.ComponentAccessor;
import com.atlassian.jira.issue.AttachmentManager;
def attachments = issue.getAttachments();
if (cfValues['customfield1']?.value == "value1" && cfValues['customfield2']?.value == "value2" && attachments.size() >= 1){
return false
} else {
return true
 But I got this kind of error :
Can you please help me achieve this ?
Jira Software version : 8.15.0
Jira Service Management version : 4.15.0
Script Runner version : 6.20.0
THANKS A LOT !
3 votes
Trudy Claspill
April 16, 2021
I think you can find the answer in this post.
https://community.atlassian.com/t5/Jira-questions/Scriptrunner-Require-Attachment-on-transition/qaq-p/850615
You may need to modify the code slightly to add the condition to require the attachments only when your custom field(s) are in the specified state.
Aimane SBAI
Thanks a lot !!!
Here is the code that worked for me :
import com.atlassian.jira.issue.IssueFieldConstants
import com.atlassian.jira.issue.attachment.FileSystemAttachmentDirectoryAccessor
import com.opensymphony.workflow.InvalidInputException
def attachmentDirectoryAccessor = ComponentAccessor.getComponent(FileSystemAttachmentDirectoryAccessor)
def temporaryAttachmentDirectory = attachmentDirectoryAccessor.getTemporaryAttachmentDirectory()
def mIssue = issue as MutableIssue
def attachmentNames = mIssue.getModifiedFields().get(IssueFieldConstants.ATTACHMENT)?.newValue
if(!attachmentNames) {
invalidInputException = new InvalidInputException("You must add an attachment")
Like # people like this
Trudy Claspill
April 19, 2021
Credit goes to @Mark Markov and Ryot for working out the code.
Steve Maccharoli August 11, 2021
@Aimane SBAI I am curious, how did you wrap the code that you said works for you above into the logic you were using for initially checking against a custom field?  I have the same use case as you (or so I think), where if Custom Field A = Value B, then attachment needs to be required on create.  I read the code above, but can't seem to see where it's checking against a custom field value prior to executing the attachment logic.
Any input would be greatly appreciated!
Naveen Penta September 13, 2022
Its working
Its working
OMAR MOHAMED AHMED MOHAMED FATHY
@Steve Maccharoli do you have any solution on this >
Christian Bär
February 8, 2024
Thank you for this solution. This is the first out of three that works still in Jira  9.4.14 in 2024. The code given here by Aimane is quite different from that in the linked article
Kudos!
