Make original estimate field required in Kanban workflow
Оксана Пурис
May 27, 2024
Hello
I work with company management project in Jira - Kanban flow
I want to make original estimate field as mandatory.
But the problem is  that when I want to make this field mandatory via the "Issue -Configuration Fields - Search" there's no such field. However I can see this field in the Issue layout.
At the same time I don't have any problem with making the same configuration for my Scrum projects
Оксана Пурис
May 27, 2024
Not relevant - I just found the answer
Laviniu Chis June 28, 2024
@Оксана Пурис Can you please share the answer as I have the same issue but no solution. Does anyone else know why this Original Estimate filed can't be found anywhere in the Configuration Fields.
Maciej Dudziak _Forgappify_
If I remember correctly, original estimate, which is a part the time tracking, is called timeSpent in configuration
Cheers
Nathan Phillips
May 28, 2024
Hello @Оксана Пурис,
Thank you for reaching out here on the Atlassian Community.
I do see that you marked your own question as answered.
I am curious, would you be able to share the resolution you found fo your question?
We might be able to help other end users with your resolution! Thanks.
