Hello!
I have scriptrunner for Jira cloud on my instance and I am not familiar with writing scripts. However, there has come a need for my team to want fix versions required based on particular priority selections.
I'm sure this is possible, I just lack the knowledge in writing the code to do it. Everything I've found online has to do with custom fields and not two "native" Jira fields.
Hello @Jane Ellis
At what point do you want that requirement to apply?
When an issue is being created?
When an issue is under going a status change?
After an issue exists and then a person edits the Priority field?
All of the above. But I know that it's going to be more difficult to trigger it on when a person just updates the issue. We're fine with the fail-safe of doing it on creation and on transition. That way nothing gets missed.
