Manage what info is displayed on the linked issues or Issues in Epic sections?
Shirley Jhirad
Hi all.
Is there a way to modify the data displayed on the 'sub tasks' section on a parent issue or in the 'issues in Epic' section in JIRA 7?
I would like to change it and decide for myself, which fields i see in the sections.
image2016-8-25 14:19:5.png
I saw there was a way in  Older JIRA versions but do not see such a way in JIRA 7
 Can anyone help?
Shirley
6 votes
Petar Petrov (Appfire)
August 31, 2016
As Tom said, there is a setting which can control which columns are visible, but this setting applies on a global scale. There is nothing you can do out of the box to change what is shown in the "Issues In Epic" panel.
That being said, if you are running JIRA server and willing to look at commercial plugins, Issue Matrix will solve all these problems for you - you can completely customize how subtasks, issue links, and issues in epics are shown - you can filter, sort, select columns to be shown (including any custom field on the system). All this can be configured on a per-project/issue type basis.
Deleted user August 31, 2016
OK, being on the Cloud, I'll just say I'm jealous!
wink
Deleted user August 25, 2016
I think what you're looking for is here:
System -> Advanced settings -> jira.table.cols.subtasks
Shirley Jhirad
Thanks @Tom Proctor
I found the setting for the sub-tasks table.
I didnt find such settings for the Issues in Epic table. Any ideas?
Thanks again
Shirley
max April 24, 2019
There is no setting like that to "Issue Links" panel ?
Shirley Jhirad
Still no solution- issue matrix  or exocet add ons are useful for that as well as to moderate the linkage between issues
Like Azfar Masut likes this
max April 25, 2019
Thank you :)
Azfar Masut
February 15, 2021
@Shirley Jhirad do you mind sharing if you have used exocet before to provide this functionality?
Julie d'Antin [Elements]
