×After upgrading my test JIRA from JIRA v6.4.13 to JIRA Software v7.1.9 I find that I am no longer able to navigate to project administration and manage either versions or components. For instance, the versions screen displays text:
> For software projects, JIRA allows you to track different versions,
> e.g. 1.0, 2.0. Issues can be assigned to versions.
..but nothing else except for a "merge" button.
Am I missing something really basic here? I am system administrator and have checked permission scheme and project roles.
The versions and components are still there. For instance, there is no problem with assigning an affects version to an issue.
JIRA Service Desk has been installed for evaluation 10 days ago, on top of JIRA Software 7.1.9. I do not know if versions/components were working inbetween the upgrade of JIRA and the installation of JSD.
The problem was nothing to do with permissions, etc. It was caused by a defect in Conditions Validator Plugin v2.1.2 (and possibly also in v2.1.1) and has been replicated by Atlassian Support. There were 4 affected areas that I found (and there may be more):
Disable Conditions Validator and all the problems disappear. I have logged a call to get the defect resolved.
