I am using Jira next-gen, and I find that sub-tasks are not visible on the Backlog view unless you drill down on the Story. Also there doesn't appear to be a way to move just a single sub-task to a sprint. Can someone tell me if it's possible to selectively move subtasks into a sprint?
The link to documentation on this page is wrong: https://confluence.atlassian.com/jirasoftwarecloud/working-with-next-gen-software-projects-945104895.html
Selecting "Manage subtasks in next-gen projects" takes you to the epics page.
It is not possible with classic boards as well. Subtasks are not visible in the backlog and if you move an issue to a sprint, then all subtasks of the issue are moved to the same sprint.
