Manual Escalation Process
Ray Balmeo Cagayon April 19, 2024
Hi All,
I had created a field (Escalation Path) and it has 3 dropdown values.
  • Category 1
  • Category 2
  • Category 3
I had also created an automation in which emails will be sent to stakeholders depending on which category they represent when there is a change of value on the field.
My problem is, I don't want them to jump directly from Category 2 without going to Category 1 first and from Category 3 without going to Category 2. In this way, higher tier will not be bombarded by emails if these can be solved by lower category tiers.
3 votes
Dexter de Vera
Hi @Ray Balmeo Cagayon ,
This cannot be done in automation. For workaround you may update your workflow and add stage/status for escalation level.  So they can escalate to next level by transitioning the status.
Register now
