I'm trying to run a manually triggered automation rule on a company-managed software project and getting this error message.
"Oops we ran into a problem
There was a problem and we couldn't run the automation "{0}"
There is no record of this failure in the audit log. This rule was previously run on February 15 without a problem. The rule create subtasks and assigns the current issue as their parent.
I'm getting report from others in our group that manually triggered automation is also failing on a team-managed service support project. Our org is nowhere near the automation limit.
There is an active incident relation to app integrations and automation within the Atlassian platform.
Hi @Marc - Devoteam & @Jack Brickey ,
May i know is this incident still persists?
because i do have a same issue. also, unable to find the Audit logs to check the issue.
Below error is from Software project.
Hi @VinayKumar Konduri , that incident was back in February and was resolved. If you are having a persistent issue then I would contact Atlassian Support.
