Match "Time Tracking" with Project Status
Jorge de Carlos October 20, 2022 edited
Hello folks,
I would like to know if there is any way to know how long time is logged in each status of the Issue
Example:
Imagine the following status for a Issue: Open, InProgress, Testing, Done
Time logged: 10h
Finally Jira reports:
  • Open: 0h
  • In Progress: 7h
  • Testing: 3h
  • Done: 0h.
Thanks a lot in advance,
Best regards,
Jorge
Madhu_RVS
October 25, 2022
Hi @Jorge de Carlos
If you would be interested in a mktplace solution, you can try out our plugin,
Time in Status Reports
The add-on provides the time in each status for the entire lifecycle of the issue .
Trudy Claspill
Hello @Jorge de Carlos
Jira does not have a native solution for this. Would you consider paying for a third party app?
