Max Threads in ScriptRunner Cloud
Andrew Lipscomb
So, as the Adaptavist docos say
REST API calls are made in a blocking style (although async methods are provided too)
Async methods look to be useful when you need to fire a bunch of updates to JIRA and don't care about the results from each. Question is; how many threads does each container get access to and what happens when that count is exceeded.
As an example; if I try something like
import com.mashape.unirest.http.async.Callback
import com.mashape.unirest.http.exceptions.UnirestException
def issueCount = 100
for (int i=1; i<issueCount; i++) {
	put("/rest/api/2/issue/PROJ-${i}")
		.header('Content-Type', 'application/json')
        .body([
        	fields:[
                summary: "This is issue ${i}"
		]).asStringAsync(new Callback<String>() {
            public void failed(UnirestException e) {
                logger.info("Exception failure ${e.toString()}")
            public void completed(HttpResponse<String> response) {
                 logger.info("Responses are pointless here!")
            public void cancelled() {
                logger.info("The request has been cancelled");
How will this break? Also I have not tested this code beyond a simple example; no guarantees this will even run.
Edit: more code typos
3 votes
Jon Mort _Adaptavist_
March 13, 2017
Hi Andrew,
Your code should work fine, there are a couple of things to be aware of.
  1. There is no thread limit, only execution time limit of 30s
  2. The number of connections to your JIRA instance is limited to 8 (this is not published and may change)
  3. You need to ensure that all the requests finish before the script completes, if you don't in flight requests may not complete, and queued requests will not start.
  4. You have a single core to run on, so don't do CPU intensive work on threads and expect things to be faster
Once you start introducing threads you're into the very advanced area of scripts. We are looking into ways to support returning an object for bulk requests, so you don't have to make them all in your script.
Jon
Andrew Lipscomb
Thanks Jon; I ended up with some time to experiment (for science!) yesterday and found that I could get around 50 async requests to fire before timeout using a sleep(XXXX) command to pause the main thread.
I guess with multi threading with the number of variables in terms of connection speed, dropped server connections and general unreliability you need to scope your solutions right.
For my designs in the 30sec constraint; if sync processing is required, I aim for max 20 API calls. If async is needed, I'd bump to max 50 API calls. If more is needed, use bulk manipulation or custom tools in Jira.
March 13, 2017
Rather than use a sleep you could use a CountDownLatch so the script doesn't run for longer than needed. You can also log so you can see if it actually finished.
import java.util.concurrent.CountDownLatch
def issueCount = 10
CountDownLatch latch = new CountDownLatch(issueCount)
issueCount.times { i ->
        .body([
            fields:[
                latch.countDown() // each part of the callback must call countDown()
                 latch.countDown()
                latch.countDown()
latch.await() // this will block until the latch is empty
logger.info("All requests completed")
Register today
