Hi everyone. I am looking for a place to put all information related to each of our properties that connects well with Jira. I discovered you can't import a CSV into Confluence. Then I thought I could create a dashboard in Jira for each but we have about 750 properties. Will I max out?
Thanks.
Hello @Erin McCutcheon
There is not a maximum number of Dashboards, but there is a limit on the number of gadgets that you can include in a Dashboard.
Thank you!
Hi , you can create a dashboard with more than 20 gadgets, if you can't to add more than 20 gadgets use this instruction > https://confluence.atlassian.com/jirakb/modifying-gadget-limit-on-a-dashboard-604275720.html or https://confluence.atlassian.com/adminjiraserver/advanced-jira-application-configuration-938847847.html
Standard and Premium Plans >No hard limit on the number of dashboards per user.
