Merging user accounts
Taylor Huston
Hi all,
I work for a company that recently acquired another company. We merged in a few of their old Jira Projects into our instance. We tried to do our due diligence, but we have ended up with some duplicate user accounts.
Basically, is there a way (probably with Scritprunner) to iterate through each issue and so something like
if assignee == somePerson@oldDompany.com then assignee = somePerson@currentCompany.com
And perform a similar action for Reporter and Comments?
Martin Bayer [MoroSystems, s.r.o.]
Hi @Taylor Huston , it is doable for assignee and reporter, but it will be difficult for comments (if you want to change mentions).
I do not have prepared script, but you need to
  1. search the issues by JQL (here is an example: https://library.adaptavist.com/entity/perform-a-jql-search-in-scriptrunner-for-jira)
  2. update the assignee / reporter (example for assignee is here: https://library.adaptavist.com/entity/automatically-update-the-assignee-of-an-issue-in-jira)
Try to put these snippets together and come back here if you need more help. We can debug your groovy code virtually :)
Gregory Kneller
the groovy code for data-center is in https://jira.atlassian.com/browse/JRASERVER-3132
SERVER
