Microsoft Word Document with Check Boxes
Laurie Thelwell
June 20, 2024
I have a Microsoft Word document (Template I created) and used the developer tab to add check boxes (under control) in an effort to simplify the document for the person filling it out.  It's a template made to collect the most important information needed for projects/demands/enhancements in Jira.  Once the document is filled out I upload it to Jira. However, the check boxes disappear when to click on the document in Jira.
Nicolas Grossi
Banned
June 20, 2024
@Laurie Thelwell Welcome. You might want to, once the doc is finished, export as pdf and actually attach the pdf instead to the jira issue?
Nicolas
Laurie Thelwell
June 20, 2024
@Nicolas Grossi that worked!   Thank you!
Like Nicolas Grossi likes this
Aron Gombas _Midori_
July 4, 2024
@Laurie Thelwell If you follow this approach, the Better PDF Automation app can reduce the work required!
As part of a standard Jira Cloud automation rule, this app can generate a PDF and attach it to an issue. It sounds that this is what you need.
(Discl. it is an app developed by our team.)
Nicolas Grossi
Banned
June 20, 2024
@Laurie Thelwell You might also want to report the bug through support.atlassian.com as you have a premium account
Nicolas
