Migrating from JIRA OnDemand to Standalone
iro_MT December 2, 2012
We are using JIRA standalone, just upgraded to 5.2.1.
Our company has purchased recently another company that was using JIRA OnDemand. (innovity.atlassian.net).
Now, we need to merge the 2 JIRAs: export data from OnDemand and import it in the standalone installation. I made the export file, copied it on the local server to the appropiate location. So far, so good.
However, when I go to System -> Restore System, JIRA says: "The xml data you are trying to import seems to be from a newer version of JIRA. This will not work."
When I go to System -> Project Import, Jira says: "This data appears to be from an older version of JIRA. Please upgrade the data and try again. The current version of JIRA is at build number '813', but the supplied backup file was for build number '6001'."
>What do?
JustinA
December 2, 2012
Hi man,
Because JIRA standalone has a different build number than OnDemand, you would need to modify the build number to ensure the project import goes well.
Can you look this up and try the project import?
Cheers!
thanks, that worked!
Abdoulaye Kindy Diallo
December 2, 2012
You could go through this documentation: Migrating from JIRA OnDemand to a JIRA Installed Site.
thanks for your answer. I read the document. I created a new jira instance on a VM and at the initial setup process I'm receiving the same error. Screenshot: http://imgur.com/0vvou
December 2, 2012
Kindly have a look at the UPDATE at this post.
I opened /atlassian-jira/WEB-INF/classes/jira-build.properties
There is no downgrade.allowed.build.number property in the file.
What I have is:
downgrade.allowed.build.version.pattern
Initial value was: 6.0-OD-01.*
tried 6.0-OD-01*
tried 6.0-OD-01
tried *
none of them work.
In the backup, entities.xml has:
___ Core Application Properties ____________
     Version                                       : 6.0-OD-01
     Build #                                       : 6001
     Build Date                                    : Tue Nov 27 00:00:00 CST 2012
     Installation Type                             : unknown
     Server ID                                     : ****-****-****-****
     Base URL                                      : https://innovity.atlassian.net
     Default Language                              : English (United States)
     External User Management                      : OFF
any suggestions?
Learn more
