I am trying to migrate one project from Jira Cloud to another instance of Jira Cloud.
I have come across this ticket which mentions a
Jira Cloud Migration Assistant
I have tried following instructions, finding the app, but to no avail.
https://support.atlassian.com/migration/docs/update-or-install-the-jira-cloud-migration-assistant/
Can someone please help me find the above app so i can use it or provide further information about it?
Or can someone help in pointing me to a tool that can help migrate a single project from Atlassian that does not cost any extra? Thank you.
Hi @Eyal Taylor
For migration between Cloud instances, please try to follow https://support.atlassian.com/organization-administration/docs/copy-product-data/
Hope this helps!
Hi @Eyal Taylor
Yep, the Jira Cloud Migration Assistant (JCMA) is a solid place to start—but it comes with a few caveats.
Here’s what to keep in mind:
OpsHub Migration Manager, an Atlassian Solutions Partner can help teams that need more flexibility by:
Hello @Eyal Taylor , before any migration, it's nice to have a copy of your data just in case to avoid data loss. To migrate Jira data between cloud instances, you can also try GitProtect (backup your data and restore to another cloud): https://marketplace.atlassian.com/apps/1228719/gitprotect-io-for-jira-backup-restore-dr-data-management?hosting=cloud&tab=overview
Hi
You’re on the right track with the Jira Cloud Migration Assistant (JCMA), but unfortunately, it’s not designed for migrating a single project between Jira Cloud instances—it is primarily for moving entire Jira Cloud sites to another Cloud or Data Center.
Options for Migrating a Single Jira Cloud Project
If you need a free method, your best option is CSV export/import. If you need an exact copy of your project, you may need a third-party app.
Let me know if you need detailed steps! 🚀
