Migration of Jira Projects
Shahzad Anjum April 23, 2020
I have to migrate projects from one Jira instance to another Jira Instance, both are in Data center however there are minor differences in version.
Source Jira instance version is 7.13.9 and target Jira instance is 7.13.5
Kindly advise.
Regards
Anjum
Jannina Koskinen
Hi @Shahzad Anjum !
You can do this easily with Project Configurator app from the Marketplace. It supports your migration even you are in different versions of Jira.
Please check here the app https://marketplace.atlassian.com/apps/1211147/project-configurator-for-jira?hosting=datacenter&tab=overview
Jannina
Hernan Halabi - Elite IT Consulting Group
Hello @Shahzad Anjum in order to do project import you must be in the same version. Once that is in place the destination instance must have the same status on the workflow and custom fields options to mention other considerations. Whenever you try to do it Jira will tell you what is missing
