Missing issues in migration from onPrem to Cloud
Marlene Pacheco
August 7, 2024
I migrated a project from Jira on Prem to Jira Cloud using the Jira Cloud Migration Assistant. According to the assistant and the post-migration report the migration was completed successfully.
However, none of the issues are visible on the Cloud site. The project is there but none if it's issues. I also checked again after 24h and 36h to account for any possible delay.
Any help is much appreciated.
Marc - Devoteam
August 7, 2024
Hi @Marlene Pacheco
My recommendation is to remove the project in the Cloud instance and execute the migration again.
If the same occurs, then raise an issue at Atlassian Support.
Marlene Pacheco
August 7, 2024
Thank you :) Will do
Like John Funk likes this
