Mobile bug
David Thomson
I made a bunch of issues on the app, but the descriptions didn't save.  It showed the descriptions on the issue normally (after returning from the description form by pressing the save button, as if it had saved normally), but I realized after making maybe 10 of them that there was a tiny little 'Description save failed' underneath the description area.
Otherwise it looked as if it had saved, when returning from the description form, except for the tiny red little error that was literally impossible to see.
So I made them again on the PC, and then realized the old mobile ones were still there, so I went to delete them but it says it has encountered an error on its end and to contact support.
This is not support, but I thought I'd mention it, regardless.
... I just checked to see if I could delete them on mobile, but it is now gone, and gone on PC also.
A nice little bundle of inconvenience there, documented here for your reading pleasure.
John Funk
October 20, 2024
Hi David,
You submit your findings to Atlassian Support:
https://support.atlassian.com/contact/#/
