Modify Scrum Software Development project template
William Tanner September 14, 2023
We have a requirement to add a field to a screen for all new projects.  The easiest way to do this would be to modify the Scrum Software Development project template by adding the new field to it.
Is there a way to modify these new project templates?  I cannot find any way to do it.
Mohamed Benziane
Take a look at the this thread, the best move it's to create a dummy project with the scheme you need and then use the create with share configuration option for new project
https://community.atlassian.com/t5/Jira-Software-questions/Create-or-modify-a-Jira-software-project-template/qaq-p/726976
William Tanner September 18, 2023
Thanks for the reply.  That is not the exact solution we prefer, but looks like it may have to suffice.
SERVER
VERSION
8.22.6
Register now
