Modify card layout on KANBAN boards?
kc_ray October 1, 2021 edited
We use JIRA extensivly with our on-prem server version, and can configure card layout on boards easily. We can add issue fields to the cards and see this on our boards.
So I'd like to do this on our Atlassian cloud instance. The help says you can? But no where can I find how to alter the card layout!
Thanks for the answers.. but this is what I get
There's my board .. click on the three ... and I get the configuration options shown in the second imageboard.png
Narendra Kumar
Hi @kc_ray  open your board and follow the below steps -
1. Go to board setting
2. Click on card layout
You can refer https://support.atlassian.com/jira-software-cloud/docs/customize-cards/ to know more about this.
Let me know how this works for you. Thanks!
Narendra
Ivan Cruz
October 14, 2021
Hi @Narendra Kumar - When I go to my Board settings, there's no Card Layout tab or option. I am using a Team-managed project in Jira cloud. What am I missing? Thanks.
Ivan Teong
November 16, 2021
Hi @Ivan Cruz
Custom card layout is currently not available in team-managed projects in Jira Cloud. You can vote for it and track its progress here: https://jira.atlassian.com/browse/JSWCLOUD-17336
In the meantime, if your team needs it urgently, you can use Company-managed projects. Sorry for the inconvenience caused.
Ivan
Product Manager, Jira Software Cloud
Callum Carlile _Automation Consultants_
Hi @kc_ray
When you go to your board, then Board settings > Card Layout tab, this is where you would be able to edit the field which are displayed on the cards
