Hi – I’m unable to remove or change report criteria for a Kanban report, a Cumulative Flow Diagram. It appears as though I can just click on the column I want to delete and press delete or something, but no cigar.
So each color corresponds to a column or status on our Kanban board. Well I want to get rid of a column, like “Backlog”, so you go into the screen where it shows all the column you can edit – I click on one but it does nothing.
Thank you!
Hi @Mike Sebastian ,
Did you click the Apply button when you chose not to display the Backlog Column?
That absolutely was the solution. Thank you! I was just pressing delete and everything but the right thing. Thank you!
