The dropdown to switch between month view and week view for the Jira calendar for Kanban boards seems to come and go. It normally appears in the top right corner.
Any ideas as to why would be seeing this intermittent behavior?
Attached a screenshot as to where it used to appear (in this top right area)
I can't reproduce this, I can see this on any board and is always there, even on boards with items from multiple projects.
What if you try another borwser or incognito window, or clear your cache and cookies.
Hi @Marc - Devoteam The problem exists across different browsers, different users, different computers. I saw the calendar dropdown yesterday and then it disappeared upon refresh.
Yesterday (Monday) there where many issues on Atlassian based to an major issues at AWS.
I can't reproduce it in 3 different instances in different project types or instances.
If it still occurs, then best is to raise an issue with Atlassian Support, as it might be something with your instance.
