More Tab in JIRA has a lot of Selections -- Need to Modify and Reduce Choices
A
October 30, 2017 edited
Hi guys,
How can I reduce the list of choices shown in "More" tab at JIRA?
JIRA version is 7.5.
Screenshot of More tab below:
Nic Brough -Adaptavist-
October 30, 2017
I suspect it's one of the Gantt chart add-ons - it's done this to another couple of users recently.
I don't believe it's configurable, it would be worth getting rid of it or replacing it with one that doesn't clobber your menus.
A
Thank you.
Mizan
October 30, 2017
Are you the administrator of your JIRA instance ?
These options do not come by default in JIRA. This is definitely via some customization , probably a custom add-on.
You will need to figure out who has done this and then disable it. Get in touch with your JIRA administrator.
Let me know if you need any help if you have no clue about this and want to get rid of it.
A
Thank you.
