×Please advise how to change the script to make it work. This script is used in the post function, the latest in the queue.
At the moment, the issues from Epic have the type DocumentIssueImpl. Because of this, the status of the last issue, which goes to the status Closed is always displayed as the previous. That is, issue.statusId shows the status that the issue has moved, and the line search.results.every{it.statusId == "6"} shows that the current issue is still in the previous status.
How to make this selection readable?
The script was edited to the correct version:
import
com.atlassian.jira.jql.parser.JqlQueryParser
import
com.atlassian.jira.issue.IssueInputParametersImpl
import
com.atlassian.jira.web.bean.PagerFilter
import
com.atlassian.jira.bc.issue.search.SearchService
import
com.atlassian.jira.component.ComponentAccessor
// Stop the script if the issue is Epic
if
(issue.issueTypeId ==
"6"
return
// ID of "Epic link" field and current user
Long EPICLINK =
14500
def
currentUser = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
// Get managers
def
issueLinkManager = ComponentAccessor.getIssueLinkManager()
def
customfieldManager = ComponentAccessor.getCustomFieldManager()
def
jqlQueryParser = ComponentAccessor.getComponent(JqlQueryParser)
def
searchService = ComponentAccessor.getComponent(SearchService)
def
workflowManager = ComponentAccessor.getWorkflowManager()
def
issueService = ComponentAccessor.getIssueService()
// Epic of the current issue
def
epicLinkCustomField = customfieldManager.getCustomFieldObject(EPICLINK)
String epicLink = issue.getCustomFieldValue(epicLinkCustomField)
def
currentEpic = ComponentAccessor.getIssueManager().getIssueByCurrentKey(epicLink)
// Stop the script If the issue has no Epic
if
(!currentEpic) {
return
// JQL to retrieve all issues in the Epic
def
query = jqlQueryParser.parseQuery(
"issueFunction in issuesInEpics(\"key = ${currentEpic.key}\")"
def
search = searchService.search(currentUser, query, PagerFilter.getUnlimitedFilter())
def
searchResults = search.getResults().
findAll
{ it.getKey() != issue.getKey() }
// Excluding the current issue, which goes to status "Closed"
// Epic's workflow
def
workflow = workflowManager.getWorkflow(currentEpic)
int
actionID =
21
// Resolved status
def
transitionValidationResult = issueService.validateTransition(currentUser, currentEpic.id, actionID,
new
IssueInputParametersImpl())
// Transition the epic to Resolved status only if all issues in the epic are closed
if
(searchResults.every{it.getStatusId() ==
"6"
String newComment =
"The issue is resolved. Please check all the updates and manually close it."
issueService.transition(currentUser, transitionValidationResult)
ComponentAccessor.getCommentManager().create(currentEpic, currentUser, newComment, false)
Please specify if there are errors or lines in my code that can be improved. I'd be grateful. (apologies if there are typos)
P.S.
The script is written in a readable form to make it easier for my colleagues to read it. They don't write scripts.
When you're iterating over issues, you could exclude your current Issue.
If I understand what you're describing, let's say for the purpose of this example the post-function is being executed on a story.
If the parent issue is Epic, you then get issues in the epic.
The transition on the story is to Done - so we know that this story is in the Done status.
However, getting the issues in Epic, the issues return their current status, however this one particular story still shows as previous status - arguably, we could say, because this story has not yet finished transitioning.
If that's the case, you could exclude it, I think this should work
search.results.remove(issue).every { .. }
which should remove your current issue from the results, if it is present in it, then you continue as you were
or with a different approach in case the one above doesn't work
boolean areAllIssuesInEpicDone = searchResults.getResults().find {
it.getKey() != issue.getKey() && it.getStatusId() != "6"
} != null
is there any issue which is not the current story, which is not in "Done" status
And of course similar for subtasks or linked issues, etc.
@Radek Dostál, thank you very much for your reply. I didn't know about the "Remove" method. Your answer was able to point me in the right direction.
For starters, we get all the issues in the epic except the one that goes to Closed status. After that, we iterate through that list. During the tests, I realized that the script logic is wrong because an epic shouldn't have issue links or sub-tasks and child issues should have them, so I changed and tested the script, so I will change my question with the correct script.
Once again, thank you very much, Radek Dostál. Advice from the outside always helps.
