Have 3 user stories that gave this error when I try to move them from work in process to to do . They are all in the backlog and not tied into anything currently . Each time I try to move I get org.ofbiz.core.entity error
Hi @Steven_Doherty ,
as this is Jira cloud, there is not much you can do to investigate the problem more.
Are you on a paid plan? It is possible for you to contact Atlassian support directly?
You can check the workflow, whether there are some suspicious post functions/conditions/validators, but you will probably need Atlassian to provide you with more information.
Show up and give back by attending an Atlassian Community Event: we’ll donate $10 for every event attendee in March!
Join an Atlassian Community Event!
