Is it possible to have two boards similar to the ones below? One at one level linked to the project level board.
image2014-10-23 17:38:19.png
Sure,Kanban without quantitative restrictions, a Project can create multiple kanban, a kanban can also correspond to multiple Project .
In your project proposal ,I think you can create a Kanban boards for Epic,and create a Scrum boards for Scrum Team
Hello Sue
You can have as many boards as you want. Each board works based on a query you define and save as a filter. Therefore if you have filter with the information you want to see, only that data will show in your board.
I hope this tip helps.
