I am working in an enterprise company, with multiple IT departments, which works on very different areas as well has very different requirements to security. Some departments have a heavy usage of external consultants, while others solely rely on internal resources.
Therefore, we would like to have multiple Jira Cloud instances setup, such that department a has one instance and department b has another, e.g:
deparment-a.atlassian.net
deparment-b.atlassian.net
Is it possible for the same company, to have several Jira Cloud instances?
Thanks in advance!
Yes, you can buy as many Cloud systems as you need.
Thanks for the quick reply.
I just wanted to make sure I did not "force" our other company departments into our cloud solution, due to some limitation,
Get Certified! ✍️Online forums and learning are now in one easy-to-use experience.
