Multiple formulas in a project don't work
Mehdi Piraee
July 27, 2016
Hi there,
When I add multiple formulas to a project they stop working. Everything is fine when there's only one formula though. Could you please let me know if this is a known issue and if there's a fix on the way.
Mehdi
Mumo Systems
Workaround: All calculated fields for all formulas need to be viewable on create, view and edit screen regardless of wether they are used by the formula or not. Permanent fix is being investigated
Mumo Systems
Let's handle this in the support from of our ServiceDesk.
Mehdi Piraee
July 27, 2016
Thanks for the quick reply Vincent. I installed the plug in last Friday after the release on 19th. There's not update option available for Abacus in the add-ons settings page.
Mumo Systems
Mehdi,
A release went out last week that fixes this issue. Please make sure your add-on has been updated in you JIRA cloud.
Register today
