Is there a planned enhancement to allow multiple quick filters selection to be applied in Jira cloud? Or best workaround for the below scenario?
At the moment the Quick Filter functionality doesn't let you show all the issue that match Quick Filter 1 plus all the issues that match Quick Filter 2. Example, selecting Quick filter 1 by Assignee =Peter and Quick filter 2 as assignee = Angela, doesn't bring any results.
The unknown workaround for this is the creation of OR/and quick filters which will include both assignees or other type of filters. This isn't practical in most scenarios, as my requirements for assignees to show together or epics/pieces of work differs all the time, so presetting the quick filter isn't useful.
Welcome to the community!
I have searched the 'JAC', which is the public database from Atlassian storing bugs/new feature requests and decisions on them (like 'FIxed/Won't do, etc'). I can't seem to find any request about it here, however I can imagine it must be somewhere since it used to be quite relevant, indeed.
However, are you aware that in Cloud, you can achieve what you're searching for using the Assignee-icons right next to the search bar on a board? Here, you can multi-select and it will 'stack' selections instead of limiting them like Quick Filters
Hi @yuliya Nayton
Currently, Jira Cloud does not have a built-in feature that allows you to select multiple Quick Filters at once
