Sign up Log in
My Automation rule executes properly but there are errors
Kenisha Naidoo November 1, 2024
Hi Everyone, hope all is well. I am new to Jira so still learning how everything works and would appreciate some help.
I have created an automation rule where if a summary contains a certain value, different subtasks have to be created. The rule works in the sense that the subtasks get created accordingly, but when the subtask transitions to a different status i.e. Open to Ready for QA, I get this error message in the audit log:
This is the rule:
The subtasks do follow the same workflow as the parent so I am not sure if I have potentially missed a step in that regard when building the rule?
Would appreciate any assistance.
2 accepted
3 votes
Marc - Devoteam
November 1, 2024
Hi @Kenisha Naidoo
Welcome to the community.
Add a condition in your rule that checks  if the transitioned issue is not a sub task.
Add this directly after the rule trigger.
Use the "Issue Field condition" set like issue type is not sub-task
Kenisha Naidoo November 3, 2024
Hi @Marc - Devoteam , thank you so much. The solution provided worked on the rule. Thanks again!
Tansu Akdeniz
November 1, 2024
Hi @Kenisha Naidoo
If parent/sub has same workflow and you want to run this rule on parent (so that subs can be created), please add a condition after "When: Issue transitioned".
Sample condition: Issuetype = xxx
So, you ensure that automation only runs for certain types, not for irrelevant types.
Hi @Tansu Akdeniz , thank you. The above did assist me.
atlassian, ace, atlassian community event, donation, girls who code, women in tech, malala fund, plan international, kudos, community badge, badge, atlassian badge, International Women’s month, International Women’s Day, women's month, women's day
10 for Change at Atlassian Community Events
Show up and give back by attending an Atlassian Community Event: we’ll donate $10 for every event attendee in March!
Join an Atlassian Community Event!
Upcoming Jira Events
