Hello, I need help working through a JQL filter in jira. The goal is to bring in and initiative level and all associated issue types from any project, and I need to pull initiative level starting in 2 different project keys (BUILD, and WORKPL).
issueFunction in linkedIssuesOfAllRecursive ("issue =WORKPL-353") AND issueFunction in linkedIssuesOfAllRecursive ("issue =BUILD-57") does not pull any issues at all, which I think is because of the AND.
issueFunction in linkedIssuesOfAllRecursive ("issue =WORKPL-353") OR issueFunction in linkedIssuesOfAllRecursive ("issue =BUILD-57") brings in over 250k issues into the search that has a lot more than just the 2 initiatives I have listed in the query.
I’d like to expand this to more than just these two initiatives, if I can figure out the correct way to write this query. Thank you!|
I can't see a way of meeting his requirements. Any of you clever people know a way?
linkedIssuesOfAllRecursive function would bring all linked issues until the end.. Using AND would not work since it would be hard to the the same logic in both sets of issues..
What kind of structure you are having? Is there any specific link that you do do the "initiative"? How many levels?
Maybe you can simply create and save a filter that would give you results of specific issues e.g "project in (BUILD, WORKPL)" or "key in (WORKPL-353, BUILD-57)" depends how many results you want - this would give you all the issues that would be "scanned".. name this filter somehow "MyFilter" then execute the linked issues function
issueFunction in linkedIssuesOfAllRecursive("filter = \"MyFilter\"")
Anyway if you want to limit there is you can also use
linkedIssuesOfRecursiveLimited
which would allow you limit the number of levels etc.
For more information how to use those functions you can refer to documentation
https://docs.adaptavist.com/sr4js/latest/features/jql-functions/included-jql-functions/issue-links
There are couple od examples that would give you an idea how to solve it.. If not please share your structure and relations and we would try to figure out together.
Well, the function parameter is a subquery, so you could write the filter there:
issueFunction in linkedIssuesOfAllRecursive("project in (BUILD, WORKPL) and issuetype = Initiative")
And you can also include the initiatives themselves by appending
OR project in (BUILD, WORKPL) and issuetype = Initiative"
But here I'm not so sure you really want "linkedIssuesOfAllRecursive", whether you just want the immediate linked issues but nothing beyond that. What also I'm unsure of whether we are talking about issue links, or Parent Link (roadmaps). IssueFunction also has 'portfolioChildrenOf(subquery)' which is more what you're after?
