Hi Team,
More field is missing in my interface. Attached screenshots
Anil
Hi @anil.katta
You might wanna check the Configuration of this issue type i.e. point 5 in your first image. Under Hide when empty section, there seem to be no fields being listed yet. That explains no More section in the issue view. Once you try to put a few more fields in the section, the "missing" part will show up.
Hi @anil.katta
If this helps please consider Accept Answer, other users with similar questions will easily find the solution. Thanks
Help us plant more trees
