Hi Team.
We have created a script to auto populate the target completion date using priority
Here TCD should be calculated using Created date + Days based on Priority
We are getting Error where i marked as BOLD
The Script is
import com.atlassian.jira.issue.IssueManager
import com.opensymphony.workflow.InvalidInputException
import java.sql.Timestamp;
import com.atlassian.jira.issue.customfields.manager.OptionsManager
import com.atlassian.jira.issue.customfields.option.Option
import groovy.time.*
import com.atlassian.crowd.embedded.api.User
import com.atlassian.jira.config.PriorityManager
import org.slf4j.Logger
import org.slf4j.LoggerFactory
import com.atlassian.sal.api.user.UserManager
import static com.atlassian.jira.issue.IssueFieldConstants.PRIORITY
def constantsManager = ComponentAccessor.getConstantsManager()
def userUtil = ComponentAccessor.getUserUtil()
log.debug ComponentAccessor.getComponent(UserManager)
//Getting Priority of the issue.
def priority = issue.getPriority()
def pname=priority.name.toString()
def issueManager = ComponentAccessor.getIssueManager()
Issue issue = issue
def TargetCompletionDate = customFieldManager.getCustomFieldObject("customfield_40742")
Calendar cal = Calendar.getInstance();
Date Created = issue.getCreated()
def temp = cal.getTimeInMillis();
def add = 0;
def x = 1000*24*60*60L
def mydueDate = new Timestamp(cal.getTimeInMillis());
if (pname == "0")
add = 21*x
temp = Created +add
mydueDate.setTime(temp)
issue.setCustomFieldValue(TargetCompletionDate, mydueDate)
def currentUserObj = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
issueManager.updateIssue(currentUserObj, issue, EventDispatchOption.DO_NOT_DISPATCH, false)
else if (pname == "1")
add = 35*x
temp = Created+add
else if (pname == "2")
add = 70*x
temp = Created+add
}else if(pname == "3")
add = 140*x
temp = Created + add
else if(pname == "4")
add = 140*x
temp = Created +add
Please Help Me
