Need Help with Behavior script?
CHINNAMUTHEVISAI.SATYANARAYANASHARMA
Hi All,
we have a requirement that when ever i select component value as "A" the assignee should be auto populated as User A. we know we can do post function that after issue creating assignee should be so and so based on Component. but here actual requirement is it should be automatically populate while creating issue only.
Valerie Knapp
April 10, 2024
Hi @CHINNAMUTHEVISAI.SATYANARAYANASHARMA , thanks for your question.
I just found this Behaviour in the Adaptavist library which I think could help you get started. Please can you take a look and let us have your feedback if this helps or not.
Cheers
https://library.adaptavist.com/entity/auto-assign-issue-based-on-selected-priority?tab=cloud
S Sajeed Ahamad September 5, 2024
Hi, I am a JIRA Developer and part-time Freelancer. I provide support for all types of Cloud and Data Center scripting solutions, including Groovy and SIL. I specialize in Listeners, Behaviors, Conditions, Validators, and Custom Post Functions. If you need assistance, feel free to contact me on WhatsApp at +17866876777 or via email at freelancerjira@gmail.com.
