Need a JQL that can provide more precise data
Dan Buchanan
October 14, 2024
I need a query where I can see both the bug priority (Blocker and High) and a label of Go-Live.
Not all bugs have these 2 priorities and a label of Go-Live
Not all bugs have a label of Go-Live that are in Blocker and High priority
Here is what I have for my JQL, but its not providing all the data we need.
project = X and priority in (Blocker, High) and status not in (Triaged, Done) and labels in (Go-Live)
October 14, 2024
Hi @Dan Buchanan -- Welcome to the Atlassian Community!
What data is not returned that you need?  Are you missing some fields in the results or are issues not returning from the search as expected?
To add additional columns, add them to the view when searching.
If some issues are not returned as expected, the way you wrote that JQL it will return issues which match all of the criteria, as the AND keyword was used: https://support.atlassian.com/jira-software-cloud/docs/jql-keywords/#AND
If you are looking for issues which match either of the criteria, please use the OR keyword with parentheses to group the logic: https://support.atlassian.com/jira-software-cloud/docs/jql-keywords/#OR
project = X
AND status NOT IN (Triaged, Done)
AND (
priority IN (Blocker, High)
OR labels IN (Go-Live)
Dan Buchanan
October 14, 2024
Thanks Bill, that provided me with the data I needed.
Like Bill Sheboy likes this
October 14, 2024
Awesome; I am glad to learn that helped.  Please consider marking this question as "answered" to help others with a similar need find solutions faster.  Thanks!
