Hi ,
We have 3 methods of Jira project export currently :
Also there is 1 more option which is through backup Manager but it exports all the projects and we need project specific exports and also its in XML format , can this be imported? as we see only csv and json formats can be imported in JIRA
We wanted to know how complete project specific export can be done (including attachements, comments etc) which can be imported in other versions (like on-prem) of JIRA?
If your most important use case is to transfer data from one Jira instance to another, then you should use the official guides. There are guides for Data Center to Data Center, Cloud to Cloud, Cloud to DC and DC to Cloud.
But, if your use case is more about exporting, then our export apps are great options to try!
Better Excel Exporter can export comments (in addition to field values, change history, etc.)!
Better PDF Exporter can export comments and embed attachment (in addition to field values, change history, etc.)!
(Discl. these are paid and supported apps developed by our team. Free for 10 users!)
