This is the pagination code I used with the (now) redacted API:
let
Source = Json.Document(Web.Contents("https://[company]",
[RelativePath="/rest/api/2/search",Query=[jql="project=TPS AND type = Story AND summary ~ OAC"],
Headers=[Authorization="Basic " & "TOKEN"]])),
totrecords = Source[total],
CurrentstartAtList = List.Generate(()=>0, each _ < totrecords, each _ +100),
//a= List.Transform(CurrentstartAtList, each """" & Text.From(_) & """"),
data = List.Transform(CurrentstartAtList, each Json.Document(Web.Contents("[Company]",
Query=[maxResults="100",startAt=Text.From(_),jql="project=TPS AND type = Story AND summary ~ OAC",fields = "assignee,created,parent,customfield_10153,creator,customfield_10015,customfield_10063,customfield_10042,customfield_10077,customfield_10051,customfield_10052,customfield_10048,customfield_10041,customfield_10024,transitiontype,description,issuetype,lastViewed,priority,progress,project,labels,resolution,resolutiondate,status,summary,timespent,updated,statuscategorychangedate"],
Headers=[Authorization="Basic " & "TOKEN"]]))),
#"Converted to Table1" = Table.FromList(data, Splitter.SplitByNothing(), null, null, ExtraValues.Error),
#"Expanded Column1" = Table.ExpandRecordColumn(#"Converted to Table1", "Column1", {"issues"}, {"issues"}),
#"Expanded issues" = Table.ExpandListColumn(#"Expanded Column1", "issues"),
etc now working with the exported records.
However, that now fails, and I can't get it to work with the new API.
THIS successfully returns 50 records:
let
Source = Json.Document(Web.Contents("https://[Company]",
[RelativePath="/rest/api/3/search/jql?",Query=[jql="project=TPS AND type = Story",fields = "assignee,created,parent,issuelinks,customfield_10153,creator,customfield_10015,customfield_10063,customfield_10042,customfield_10077,customfield_10051,customfield_10052,customfield_10048,customfield_10041,customfield_10024,transitiontype,description,issuetype,lastViewed,priority,progress,project,labels,resolution,resolutiondate,status,summary,timespent,updated,statuscategorychangedate"],
issues = Source[issues]
in
issues
But I don't know the syntax needed to paginate.
Any help greatly appreciated!
You need to use the nextPageToken option.
