×Hello,
Need help on this.
We have number custom field
*Target Systech360 version Drop down field-
values-1.10.0
1.9.0
1.8.0
1.7.0
*Target Unisecure version Drop down field -
values- 8.14.0
8.13.2
8.13.3
8.13.1
Autopopulate custom field Enable SSO if unisecure 8.14.0, systech360 1.10.0 and above versions- Autopopulate Enable SSO- Check box click “yes”
If Enable SSO is checked yes then another field Azure AD Information ie Text field should be on the create screen if “no“ this field not required. please help me to achieve this.
Rahul
