Need scripted custom fields= to calculate sum up based on other field values
Nagaraju April 20, 2023
I need Scripted field will sum up the score values and show it in the ticket on.
For example, I have 3 fields called
  1. Sensitive = Values are Yes, No, Others (Score Values Yes=5, No=0)
  2. Automated = Values Yes, No (Score Values Yes=10, No=5)
  3. Region = Values are USA, UK, Africa, Chinna, Brazil (Score Values USA=8, UK=7, Africa=5, Chinna=6, Brazil=7)
I need a script field that calculate values numbers.
ex Sensitive=Yes, Automated=No, Region=USA Total values 5+5+8 = 10 should be on scripted field.
Arkadiusz Baka
def CustomFieldManager = ComponentAccessor.getCustomFieldManager()
def a = CustomFieldManager.getCustomFieldObject(xxxxx)
def b = CustomFieldManager.getCustomFieldObject(xxxxx)
def c = CustomFieldManager.getCustomFieldObject(xxxxx)
def aValue =  issue.getCustomFieldValue(a)
def bValue =  issue.getCustomFieldValue(b)
def cValue =  issue.getCustomFieldValue(c)
int aDigit
int bDigit
int cDigit
switch(aValue){
    case "Yes":
    aDigit=5
    break
    case "No":
    aDigit=3
    break
    default:
    aDigit=0
switch(bValue){
    case "Yes":
    bDigit=10
    break
    case "No":
    bDigit=5
    break
    default:
    bDigit=0
switch(cValue){
    case "UK":
    cDigit=8
    break
    case "Africa":
    cDigit=7
    break
    default:
    cDigit=0
int sum = aDigit + bDigit + cDigit
return sum
Nagaraju April 26, 2023
Hi @Arkadiusz Baka , Thanks for your reply and code,
It worked for single list field but for multi select field it is not working, I have modified the code to get multi select field value but no luck,
Can you help me that same?
Arkadiusz Baka
April 28, 2023 edited
Multi select field is a list. Try something like that:
HashMap<String, Integer> country = new HashMap<String, Integer>();
// Add keys and values (country , value)
country.put("USA", 8);
country.put("UK", 7);
country.put("Africa", 5);
int count=0;
for (String key:list) {
if (country.containsKey(key)){
count+=country.get(key);
Where list is getting form multi select field
Nagaraju May 1, 2023
For my case "Sensitive" and "Automated" is single list and Country is multi select field.
Help me the same.
Arkadiusz Baka
Something like that
int aDigit = 0
int bDigit = 0
int cCount = 0
switch(aValue){
    case "Yes":
    aDigit=5
    break
    case "No":
    aDigit=3
    break
    default:
    aDigit=0
switch(bValue){
    case "Yes":
    bDigit=10
    break
    case "No":
    bDigit=5
    break
    default:
    bDigit=0
for (String key:cValue) {
cCount+=country.get(key);
int sum = aDigit + bDigit + cCount
return sum
Let's build A Rovo Agent 🤖
Save your spot
