Need to export all attachments from a single Project - JIRA Cloud
Jacqy George February 1, 2018
Is there any way I can export all Attachments from all tickets in a single project?  I have 706 tickets in a single project and need to export all attachments without going thru manually and doing so.  Is there any way to do this?
Thank you!
Jacqy
2 accepted
Community moderators have prevented the ability to post new answers.
Post a new question
Ilya Reshetnikov July 4, 2019
Hi @Jacqy George ,
I used the following solution a while back to export all attachments from JIRA OnDemand, I think it still might work for JIRA Cloud.
How to export attachments from JIRA OnDemand
ILYA
Ting
August 30, 2020
For Jira Cloud, can use this script written by one of the Atlassian Support Engineers to download the attachments from Filters.
https://bitbucket.org/snippets/atlassiansupportprojects/nedyBb/download-files-attached-to-the-issues
Like Robert Quinn likes this
Darryl Lee
September 11, 2020
The script above was awesome, however it dumped all attachments into the same folder. I made some changes to allow it to download attachments for each issue into a directory named after the key.
It's a little rough, because I got hung-up on shell quoting/escaping and ended up hardcoding my username:api_token into the curl command. If anybody has more l33t shell scripting skills, please please let me know the fix.
downloadbykey.sh:
https://gist.github.com/darryllee/22ea98ccf639c303813a3ad4a2ad3480
And if you don't include the time I banged my head against the table figuring out the right arguments for jq and xargs, it's way faster than Ilya's method of running a backup and extracting the files from it.
On the other hand, Ilya's technique would have come in handy that time a project was accidentally deleted along with all the attachments. :-O
Like # people like this
Hoc
Hi @Darryl Lee
Thanks for providing the script.
Im attempting to use it. Im not familiar with scripts and was wondering if you're able to help me get it working.
Have I got the correct values filled out?
Once I have the correct details do I just double click on it for it to run?
Where does it save the files in which directory?
David R. Hedges
February 1, 2023
I tweaked @Darryl Lee's script to save attachments using their original filenames:
https://gist.github.com/omegadrh/f4b3e43049b819ec18597c21f67578d4
@Hoc , if for some reason you're still interested in a response (or someone else with the same problem), I believe the likely issue with your screenshot is the presence of quotes around ARIB. You'd just want it to be "project = ARIB AND NOT attachments is EMPTY".
Once you have the correct details, you'll want to put this script in its own directory (e.g., 'Downloads -> attachments), open a terminal, navigate to that location (e.g., something like cd Downloads/attachments ), then run the command (without quotes) "chmod +x downloadbykey.sh"), and finally "./downloadbykey.sh" (again, without quotes). The attachments should appear in directories named after each issue key (e.g., ARIB-123). If you use my script, the attachments should have their original filename as specified in Jira; Darryl's script will name the attachments just as their Jira-internal attachment id number (e.g. 546793).
Hoc
Thanks @David R. Hedges for spending the time in replying. Its been a while since I posted. In the end I used a app to download all the attachments. I definitely have to give this a shot as a different option in case I need it in the future
Thank you once again for your help :)
Thomas Deiler
February 2, 2018
Dear @Jacqy George,
two ways:
The rude one:
Go to the jira home's attachment directory and copy all files of the project. Disadvantage: you have not the original file names.
The api one:
Use the REST API search request to pull first all Jira issues of your project and then parse for each issue the attachment list. The JSON variable content keeps the URL to an attachment. Of cause the filename is also available. Then, one HTTP GET later for each attachment, you got them all.
So long
Thomas
Thomas Deiler
February 6, 2018
Dear @Jacqy George,
how did you solve your issue? Do you need more help?
So long
Thomas
Jacqy George February 6, 2018
Hi @Thomas Deiler
We will try option 2, API but haven't had a chance to try this out yet.
Jacqy
Ting
April 10, 2019
The rude one:
If you're on Jira server, you can run this database command to get the to combine Unix command with the file name:
select ( 'mv ' || project.originalkey || '-' || jiraissue.issuenum || '/' || fileattachment.id || ' "' || project.originalkey || '-' || jiraissue.issuenum || '/' || filename || '"' ) as command from fileattachment join jiraissue on fileattachment.issueid = jiraissue.id join project on jiraissue.project = project.id where project.pkey = '<project-key>';
Example results:
mv PROJ-10/10031 "PROJ-10/screenshot-1.png"
mv PROJ-23/10000 "PROJ-23/screenshot2.jpg"
mv PROJ-23/10002 "PROJ-23/image.png"
Then run the command in terminal to rename your files.
iSoft STE April 22, 2019
Thank you very much for the information, you have helped me complete a process.
Chuck April 30, 2019
Where can I find the Jira Home Attachments directory?
iSoft STE April 30, 2019
JIRA Administration-->System-->System Info-->File Paths
In our case: /var/atlassian/aplication-data/jira/data/attachments/
Regards.
Tito Vilchez May 5, 2020
@Ting You rocks!  Thank you very much. Your tip was very useful.
4 votes
Daniel March 19, 2019
Hey Jacqy,
did you manage to download all your attachments? If not there are also two Marketplace Solutions which should make this a breeze.
If you use Jira Server have a look at Download Attachments. If you are on Jira Cloud check out Bulk Attachment Download.
Disclaimer: I am the developer of the cloud solution.
edgar.vasquez October 25, 2021
Hi Daniel,
I am trying to export all issues in 1 jira cloud project (with all attachments/images etc) and migrate them to another jira cloud project in a different instance. Can the Bulk attachment app attach all the image/files to each issue and upload them?
Darryl Lee
October 25, 2021
For bulk import with attachments you can use CSV but you'll have to upload your attachments to a website that is accessible by Cloud.  Details here: https://support.atlassian.com/jira-cloud-administration/docs/import-data-from-a-csv-file/
Wesley
February 18, 2022
You can use the Jira-Python library to do this.  The advantage here is that you could deliver your output in a way that suits you.  This example saves all of the attachments in subfolders by IssueKey under the Project name.
Project Name
   -> IssueKey1
        -> Attachment 1
        -> Attachment 2
   -> IssueKey2
        -> Attachment 1
https://github.com/foundingpadres2/python-jira-exports/blob/1cb15e038f6c5caedc70c84f1556f59d205ae874/jira_attachments.py
Prasad Bharadwaj July 8, 2022
i'm using Jira cloud. i'm not a developer by the way, So where do i add this python scripts in my Jira cloud to get the attachments as shown by you?
