Need to write automation Rule
Uzmii February 5, 2024
Hi All,
My automation Rule is not working for below mentioned scenario. Can you please help. Thanks
Whenever I create a bug:
3 subtasks should automatically create within that bug.
2 accepted
Bao Truong
Hi Uzmii, this is my suggestion for this rule
@Bao Truong thank alot for your timely response. I have tried your method. It creates only first subtask and does not create the 2nd and 3rd subtasks.
Bao Truong
@Uzmii  I believe the reason why only one sub-task is showing up on the UI is that the rule takes some time to run. When the bug was created, only the first sub-task had been created, hence only one sub-task is being displayed on the UI.
To view all the sub-tasks, you need to refresh the page. However, there is no need to worry as all the sub-tasks have been created properly and all the data has been stored correctly.Screenshot 2024-02-06 at 11.01.35.png
Uzmii February 6, 2024
Hi Bao.. Thanks alot for your help. It worked.
Nikola Perisic
February 5, 2024
Welcome to the community @Uzmii !
  • Trigger - issue created
  • Condition - if the issue type equals Bug
  • Action - Create 3 subtasks by adding the fields
@Nikola Perisicthank alot for your timely response. I have tried your method. It creates only first subtask and does not create the 2nd and 3rd subtasks.
Nikola Perisic
February 5, 2024
@Uzmii Can you post a screenshot of your automation rule?
@Nikola Perisic Your method works but I have got the issue. All 3 subtasks are getting created but only when I refresh the page after creating the bug. Any reason why is that happening?? thanks
So I create a bug.
Only first subtasks is visible.
When I refresh the bug. Rest of the two subtasks start appearing.
Nikola Perisic
February 5, 2024
@Uzmii Are you using a different automation rule? Since from my side, it automatically creates 3 sub-tasks after the issue of a bug has been created?
No I am using the same rule as you suggested. Not sure why page refresh is required to show all 3 subtasks
Nikola Perisic
February 5, 2024
@Uzmii Interesting indeed. Try using the incognito or clearing the cache in your browser.
@Nikola Perisic A separate question.
Can we somehow run this rule also on all the bugs that were created in the past or this rule can only run for the new issues?
Nikola Perisic
February 5, 2024
@Uzmii This automation rule can only create sub-tasks for the new created bugs.
Any change in the rule that would run it on the existing bugs as well?
Nikola Perisic
February 5, 2024
Sadly, no. When automation was set today, it will reflect on the future bugs that were created.
February 5, 2024
Hi @Uzmii
As a work-around to add the subtasks to the existing bug issue types...
Copy your rule, and change the trigger to Scheduled, with JQL for the bug to which you want to add issues.  That rule can only process 100 issues at a time, and so the JQL must correctly detect when not to add more subtasks.  You can run the rule repeatedly until it updates the existing bugs, and the disable (or delete) the rule.
Hi @Bill Sheboy
Thanks alot. It worked.
Like Bill Sheboy likes this
@Nikola Perisic thanks alot for your help as well
