Neeed SQL query to fetch the projects having Test issue type
Naveen LK
February 24, 2020
Hi All,
Neeed SQL query to fetch the projects which are having Test issue type with the Count of the the Test issues and project admins list of those projects.
Naveen L K
sukkeong
February 24, 2020
SQL? Are you attempting to query for data directly from the database?
Naveen LK
February 25, 2020
Yes
Even if i get SQL query for project list with number of tests in each project, it will be helpful
sukkeong
February 27, 2020
I would not recommend performing query directly to the database. Querying through the application, i.e. using JQL in a REST API call would allow use of the same datamodel abstraction users experience through JIRA.
IMHO,
  • querying directly from the DB is not scalable or portable if and whenever Atlassian updates the DB schema.
  • access to DB should be restricted to the application as good security practice.
