On the road map for epics, it says we will be able to view epics that have been updated. I was curious as to what "updated" will mean. Does that mean if the issue itself is updated, or if any of the issues assigned to the epic is updated (this is what I am needing).
Thank you
@Russell Stanford, not actually sure. can you share the reference where you are reading this so I can possibly answer?
