No Quotes, Info Panel, etc. opitons in the Rich text editor
Fengjie June 29, 2022
JIRA Software 7.6.3
There are no options for Quotes, Info Panel, etc. in the Rich Text Editor.
May I know how to enhance it?
Dam
June 29, 2022
Hi @Fengjie
for quote you can switch to text in the editor and use:
{quote}
your text to quote
{quote}
It will work perfectly...
For others panel there is no option at all, but as a workaround you can use icons to display infos, errors or warnings :
(i) (x) (!)
I hope this helps.
Dam.
