Not Seeing subtasks on Rapid Board in the Issue Details Panel
Robert Pepitone
When viewing a story (with sub tasks) on the Rapid Board (in plan or work mode). I expect to see its subtasks contained in the panel to the right. Instead it says “there are no sub tasks”. In fact when I create a sub task from that panel, the sub task is created without problem but a green message is briefly displayed saying “Your subtasks are currently not visible”. When I drill into the story they are there but they're not displayed on my rapid board.
Any ideas what I'm doing wrong?
sclowes
August 21, 2012
The filter for your board is probably not including the sub tasks. Check that the filter includes the sub tasks and that they are in a status mapped to a column on the board.
Shaun
Robert Pepitone
Ok...you've given me a good clue here. It seems that the subtasks are not picking up some attributes from the parent stories and that's why they're not displayed on the rapid board. The attributes in question are from custom fields that I've created for the parent stories.
How can I ensure that sub tasks pick up custom field values from their parents?
Justin Corcoran
August 21, 2012
You could try a plugin like this one: https://marketplace.atlassian.com/22274 to copy values from the parent to the child.
Jo-Anne MacLeod
August 21, 2012
What version of greenhopper are you using. This issue has apparently been resolved in 5.9.5. If its a older version than that, can you upgrade?
Robert Pepitone
I'm using a Greenhopper trial version - 6.01. What else could it be?
